RobJ
Elite Member
I've never heard turbos as helping fuel econmy. That's obvious in a turbo car because your foot was always in it. And the only problems with a gas turbo was it usually was an aftermarket kit, if a gasser is designed for a turbo things tend to work out better. I recently rented a Mazda cx7 with a turbo. 4 banger and 255 hp? Didn't impress me, mileage was also poor.
Anyway on a tractor a turbo means more power, anytime you add more power you need more fuel. So IMO the 2 engines of the same displacement, the turbo is still going to use more fuel under load.
IMO, they are adding turbos to small engines these days for one reason only...cheap hp. What's cheaper, redesign a bigger engine, different internal parts even if the exterior is the same size or add a couple new manofolds, oil lines, bigger air filter and a turbo. Then you can say more hp!!
I don't have a problem with a turbo lasting a long time. They will probably need service before the engine does. But it's a coin toss I guess.
Do you really need a turbo: (JMHO here)
Doing some FEL work? No
Doing some yard mowing with a FM,? No
Taking that 12" Coastal down to 3"? No. Bahaigrass, al little harder but no.
Taking 6' Johnson grass down to 3"? Yes
Pulling a disk in 1000' rows? Yes
pulling a bottom plow in long rows? Yes
pulling a planter, No
Boxblading No
straight blading a gravel road, No
Long continious loads is where you see the benefit. If you are using foot throttle a lot, then probably not. I think they work better in a non HST tractor. To me if I buy an HST tractor I'm going to be going back and forth a lot. If I buy a gear tractor I may have large hay fields to cut, where I might not use the clutch for several hours while working. JMO.
They do have that cool turbo sound when loaded. That's worth something.
Rob
Boxblading No
Rob
