turbo or not
   / turbo or not #11
I would think that a 40 hp tractor without a turbo would be better than a 40 hp tractor with a turbo...just thinking...
David from jax
   / turbo or not #12
David from jax
In Florida at sea level your thinking works well, in the Rocky Mountains not so much.
   / turbo or not #13
I've owned 3 tractors prior to my turbo'd 5303 I have now. I can see the difference when it is under load with a bush hog or plow, no stalling. Even with the 80 HP I had before this one, I could slow it down with the bush hog, the turbo kicks in on this one & keeps on trucking.
I guess i'll complain should I ever have to replace it though.
Ronnie
   / turbo or not #14
Someone once said: There's no replacement for displacement.
I wonder if he was a turbo hater? :shocked:
If in doubt, go to the dragsters www and they will give you plenty of proof that cubes matter. On turbos for me, having had an 800 cu in Cummins 400 hp Big Cam turbo with a power band of 300 rpm in an operating range of 0-1800 rpms (took a 15 speed tranny to get useful work out of it).......just something else to fail, take up space under the hood, and be offered in liew of what a tractor really needs.....cubes for lugging...........course I'm under 1000' of elevation too.
   / turbo or not #15
Depends on what you value and/or what type of owner
(IMHO), if you plan on owning for the long term, turbo's are the weak link in an otherwise long life diesel motor. However, they can be replaced, for a price.
Like Sandman refers to: I'd take a 40 hp non-turbo to a 40 Hp turbo engine. .....they'd of course be totally different engines, c.i.'s, weight, torque curves, etc...
   / turbo or not
I asked this before: What is your altitude in PINNACLES, North Carolina?
Altitude should be a key determinant in your decision.
About a 1000 feet
   / turbo or not #17
I have a turboed tractor, I don't notice it, it doesn't whine or make noise like one you would have on a truck, all it does is spin and gives me a few extra HP's.
One thing I did learn is if the exhaust faces forward like mine and you tow it, the turbo can spin backwards from the updraft during towing, so it's best to cover the exhaust during transport, I was told.
I really have no opinion either way on turbo aspiration and natural aspiration Tractors.
I guess my question would be how long do they last?
Off that answer you can decide. For example if one lasts 5000 hours a homeowner isn't likely to rack up that many hours on a tractor so it won't affect them either way.
   / turbo or not
That is crazy - you would think dumb engineers would turn the end of the exhaust down a bit to keep that from happening. Just one more thing to think about.
   / turbo or not #19
I expect exhaust gasses are pretty hot and that is why the exhaust faces away from the operator. The turbo is BLOWING.
   / turbo or not #20
There's a thread on here that CAD started when he got a turboed tractor, that was one of the suggestions is to cover the exhaust when in tow, another was let the tractor idle for a few mins before shutting down to let the turbo cool off a little, I always do that anyway so no worries there.
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
Kubota M108S (A53317)
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
202475 (A54757)
202475 (A54757)
2003 Big Tex 10PI...
