Turf and R4 tire choice for B tractors
   / Turf and R4 tire choice for B tractors #1
Chessie
Bronze Member
South Eastern PA
B3030HSDC
Greetings,
I have posted in the Kubota pictures section a picture of my B3030HSDC with a turf and r4 industrial on the rear at the same time. there is not a lot of lean due to the size offsets. You can see the turf fills the wheel well pretty good and the R4 has plenty of room. I got both sets to be easy on the yard when mowing and the R4 for moving rock and construction garbage around. Turfs ride really nice and the R4's let you know its a tractor. Enjoy
Jeff
Howdy,
Standard truck size lug wrench will take care of all the studs. A large jack to lift the rear of the tractor (large because you need the lift height) If you have a front end loader you can use that to pick the front end off the ground with. Front tires take about 15 minutes. Back tires are about 45 minutes. Keep in mind the rear tires are heavy so wear a back brace when you are removing and installing. If your tires are filled with ballast God help ya /forums/images/graemlins/shocked.gif.
Jeff
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
GENERAC ST20-S 2IN WATER PUMP (A52472)
GENERAC ST20-S 2IN...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
