Turf and R4 tire choice for B tractors
   / Turf and R4 tire choice for B tractors #1
Chessie
South Eastern PA
B3030HSDC
Greetings,
I have posted in the Kubota pictures section a picture of my B3030HSDC with a turf and r4 industrial on the rear at the same time. there is not a lot of lean due to the size offsets. You can see the turf fills the wheel well pretty good and the R4 has plenty of room. I got both sets to be easy on the yard when mowing and the R4 for moving rock and construction garbage around. Turfs ride really nice and the R4's let you know its a tractor. Enjoy
Jeff
Howdy,
Standard truck size lug wrench will take care of all the studs. A large jack to lift the rear of the tractor (large because you need the lift height) If you have a front end loader you can use that to pick the front end off the ground with. Front tires take about 15 minutes. Back tires are about 45 minutes. Keep in mind the rear tires are heavy so wear a back brace when you are removing and installing. If your tires are filled with ballast God help ya /forums/images/graemlins/shocked.gif.
Jeff
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
CAT Skid Steer (A50322)
CAT Skid Steer...
