Turfs sound right?
   / Turfs sound right?
if he's going turfs for soil damage, and a loader.. I'd look into wheel weights he could remove when mowing vs loaded rears. desides.. loaded rears on a subcut isn't going to be much weight..
soundguy
Sound like a good possibility...weights on rears easy to remove? Cost...I'm guessing maybe a couple hundred?
   / Turfs sound right? #22
wheel weights are easier to remove than ballast inside the tires that's for sure..
soundguy
   / Turfs sound right? #24
soundguy
Yeah, and if your back is as bad as mine, pick up one of those cheaper engine hoists at Harbor Freight for installing and removal.
   / Turfs sound right? #25
yep.. cherry picker.. or chain hoist from a tree limb. both would work good.
soundguy
   / Turfs sound right? #26
I'm thinking turf tires would be good for a small tractor that will mostly mow grass, do some landscaping/loader work, tilling a garden. Will not be going into the woods or doing heavy farming work.
Pretty sure big farming tires wouldn't be good, or the r-4?
It would be nice if you could dedicate one piece of equipment to each task but most people can't do that so narrow down just what you need the tractor to do the mojority of the time. I bought my JD 3520 for everything to do with landscaping and lawn aerating/overseeding and got the R4's. I do have zero-turn mowers because thats my business but if my tractor was going to be my only equipment for mowing I would have gone with the turfs and made due with their performance in other situations. No matter what you use to cut grass or anything else you still have to do it under the right conditions, its either the right time or it isn't.
   / Turfs sound right? #27
soundguy
I took advice like that once...
After I woke up and moved the tree limb off my chest (don't worry....my head broke the fall!) and had the x-rays and one day hospital stay (the concussion, y'know), I went out and bought that engine stand.
See, I'm taller then the engine stand, so I don't have to worry about something falling on my head...now, I just need to get the steel toed boots...
This is just a fable, of course...just make sure any branch you rig to is healthy and stout enough to handle the weight
   / Turfs sound right? #28
Another thing that people seem to forget is, not all tires of a certain type are created equal. There are different grades and load ratings even for turf tires. I found that my fronts are available in either 4-ply or 6-ply. The 6-ply has a significantly higher load rating.
Just muddying the waters a bit more.
Joe
   / Turfs sound right? #29
just have to pick your tree limbs better!
soundguy
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
