Turn Signals on 2010D
   / Turn Signals on 2010D #1
nuvz
Laramie, WY
Yanmar 2010D
I know this isn't a huge problem, but it iritates me anyway. What I am talking about is the turn signal switch. You move it left & the right light comes on & vice-versa. What' up with that?? It just seems odd. Also, there is no hazard flasher on this model. Any simpleway to rectify this?
   / Turn Signals on 2010D #2
Sounds like you need to switch the wires (or just sit backwards).
   / Turn Signals on 2010D #3
It's not really backwards. If you'll notice the top of the switch has a small point on it and the bottom of the switch just has a lot of overhang. I thought the same thing so I switched my wires.
Eugene
   / Turn Signals on 2010D #4
<font color="red"> Also, there is no hazard flasher on this model. Any simpleway to rectify this? </font>
On my 1610D there are 2 green wires leaving the switch, one going to each light. I shorted the two toghther by the switch and now I can turn the switch either way and I have hazard flashers.
Rich
   / Turn Signals on 2010D #5
I replaced mine with amber strobes. Tied the 2 together since I don't need turn signals. Turn the switch either way and the strobes start.
Thanks to all! I will simply shrt the wires and be done with it!!
   / Turn Signals on 2010D #7
I tied mine in with the head lights as I have no need for turn signals either. Now they act as running lights.
   / Turn Signals on 2010D #8
Not wanting to start a new thread I did a search on this subject and it is exactly what I am dealing with. I wanted to make my turn signals into hazards so I wired them together and they did work but are noticeably weaker. Can I put a larger flasher in the circuit to make them brighter and longer flash? Right now they are weak and a real short flash.
   / Turn Signals on 2010D #9
could be the flasher. I've replaced mine a couple times
   / Turn Signals on 2010D #10
Yeah I'm gonna try and replace the flasher, any idea on part number/type? Can you pick one up at local auto parts store?
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A52128)
2018 Ram 5500...
John Deere Hayrack (A50515)
John Deere Hayrack...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
CATERPILLAR 257B SKID STEER (A51242)
CATERPILLAR 257B...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
