Turning Plow
/ Turning Plow #1
Fisherman305
Monroe County WestVirginia
How do I use a turning plow? I have a single 14 turning plow and having trouble adjusting it.
If it plows too deep what can I do? (It has a bottom adjustment. What is it for?
Ater plowing the first furrow I need to place the tires in the plowed furrow and then make the side to side adjustment am I correct?
Where should the lift arm pin be? Level or off set I can rotate one 360 degrees and not sure where it should be?
/ Turning Plow #2
Set up the plow for level running with the rear wheel in the previous furrow. The other adjustments are to keep the plow pulling straight. The top link adjustment on a 3 point hitch plow is used to regulate the depth the plow runs at. In any case it won't be much more than 8".
/ Turning Plow #3
Easiest and simplest way I have found to set a plow for the furrow, is to put a block of wood (8" block if you think you want to plow 8" deep, but I set for 6" furrow depth) under the LEFT wheel (front and rear) while the tractor and mounted plow are on a flat surface such as a concrete pad. Then lower the plow to the concrete and adjust it so the bottom of the plow rests flat - right to left and front to back. Also set the plow to follow behind the tractor such that the right side of the bottom of the plow is about 2-3" from the inside edge of the furrow. You want the 14" bottom to turn about 16" of dirt over into the previous furrow. The 2" is to hold the dirt while it is being turned.
The top arm will level front to back, and the right side adjustable pin will align the tracking and the level of the plow bottom right to left (also use the right 3pt lift arm adjustment to level right to left).
While actually plowing, lengthening the top arm to tip the leading tip of the plow down a bit may be necessary to keep the plow in the ground.
A good draft control system will help keep the plow at the correct level, but CUT's usually don't have this control. With it, if the plow starts to bury itself because of hard ground or clay, and that causes the wheels to spin down, making the plow go deeper still, then the draft control senses the compression on the top arm and lifts the 3pt until the compression on the top arm decreases. The arms then return to their original position. Without draft control, the operator has to continually make these corrections by adjusting the 3pt arms.
/ Turning Plow #4
The Instructions From a JD plow owners manual, the tire settings on the tractor are the major determining factor in how much the front plow cuts (1-2-3-4 bottom plow all the same) and keeping it centered with the tractor--from the inside of the right rear tire rubber to the center of the drawbar, you need 23 inches for 12" bottom plow--25 inches for 14 inch bottom plow and 27 inches for 16 inch bottom plow--We have used these initial setttings for decades and they works on all brands plows and all tractors--We have found that this in the single most important initial setting when mounting a plow---Ken Sweet
Sweet Farm Equipment Co. *Canmer and Munfordville, Ky*
/ Turning Plow #6
If this is correct how can someone plow with a yanmar or similar JD or ford, they dont have 2 feet from the inside of tire to the drawbar?
/ Turning Plow #7
On most 1 bottom plows, you can cheat some, by sliding the plow over on the cross hitchbar. Ken Sweet
JOHN DEERE 1700 - 6R VACUUM PLANTER (A63291)
JOHN DEERE 1700 -...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
SHEPPARD 400 GAL FRONT MOUNT POLY TANK (A63291)
SHEPPARD 400 GAL...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
