Turning with dual brakes, when, how and how often do you use them?
   / Turning with dual brakes, when, how and how often do you use them? #11
Never. I always use the steering wheel to turn and let off the pedal to stop and mash it backwards to go in reverse while turning the steering wheel to change directions.:) When I saw my B3200 on the dealers lot someone had flipped the lever over and the brakes were seperate so I asked Steve Barlow what was wrong with the brake pedals, he grinned and flipped the lever back over to lock them together and told me to just leave them locked together. I know LBrown I'm not very observant after all the different tractors to not know everything there is to know about each one. Again, if I had three of the same tractors I also would know everthing there is to know about that particular model and as I said before I'm blind.
you probably don't want to use it in the front yard. I use mine a lot when in soft soil and the fronts won't turn. Usually when I have something on the 3pt and the front end is lighter because of this.
Rob
That's a great application, I've had situations that the fronts won't turn and have to back off on the turn to get turning again.
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2000 Genie Man Lift (A50322)
2000 Genie Man...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
