turning with implements on the ground
   / turning with implements on the ground #11
That's for ground engaging implements. For floating or wheeled implements like cutters, it's not necessary.
Cripes, I don't know how I got involved in this. I already stated lifting is for ground engaging implements. My question was "tongue in cheek".
Besides, the article shows a three point with a horizontal draw bar too.
:rolleyes:
   / turning with implements on the ground #12
Yu may cant make full turns with a disc or moldboard etc but you can swerve a little bit before you after to raise it . **** that one reason they made gps lol
   / turning with implements on the ground #13
This is at the point of ridiculous.
Anything 3pt attached is a more rigid piece than something tongue-attached. No tractors' 3pt linkage is indestructible. Use your head. A 3pt mounted plow, disc, riser, no-till, etc will not turn a corner while fully engaged. Simple laws of physics and Newton and Einstein, etc. You lift these implements on corners and turns.
A shredder or bush-hog or brush cutter or topper (all the same thing) is not a ground-engaging tool. Do not drop them to the runners and just take off. Look over your shoulder. Watch them. Pay some attention. Your 3pt arms should not be shifting hard left/right and or binding the PTO while going about your business.
Tongue/drag implements are a little different. Not always. You just have to know them.
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2016 KOMATSU PC360LC-11 EXCAVATOR (A53843)
2016 KOMATSU...
