TWIN or SINGLE cylinder better? Kohler or Briggs?
   / TWIN or SINGLE cylinder better? Kohler or Briggs?
is I/C mean Briggs Intek? what's the 'C' stand for?
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #13
From a pure grunt perspective, see if you can find the maximum torque output rating for the Briggs engines. You'll find everything you want to know about the Kohler engines on their website, even the technical manuals are available free.
When I was looking for a small LT - the single cylinder Kohler, although only rated 16hp - had just as much peak torque as the twin cylinder 17hp Kawasaki that would have been the next engine up. So far that little Kohler has run very well.
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #14
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #15
The I/C stands for industrial/Commercial lookee here
web page It is not an Intec Intecs are a different engine.
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #16
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #17
My main point is to buy an engine with a steel or cast iron sleeve in the cylinder for longer life.
Will an 18hp 2 cyl or an 18 hp one cylnder engine burn more gas per acre mown ?
   / TWIN or SINGLE cylinder better? Kohler or Briggs? #18
the 22hp Intek V-Twin and the 22 I/C Twin are the same exact specs.
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
CATERPILLAR 740B OFF ROAD DUMP TRUCK (A52705)
CATERPILLAR 740B...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
2014 Infiniti QX60 SUV (A55758)
2014 Infiniti QX60...
