I have the SpeeCo from TSC, it works like a charm. The reason the cycle time is a little longer is because it's a 24" cylinder situated to accept a 26" chunk. As I said, 24" cycle time at 7.66 gpm is about 21 seconds. That extra 2" is actually 4" when you count both directions. That probably accounts for the longer cycle time.
But I'm retired too, and appreciate a comparatively slow cycle time. The trick to shortening cycle time however, is don't let the ram retract any farther than the length of the next chunk. If you only split 18" sections for example, stop the ram before it fully retracts. If you don't trust your eyeball, they make horseshoe shaped cylinder stops that you slip over the ram so that it won't retract all the way back into the cylinder.
//greg//
