TYM 503 3pt Lift Arm(s) Not fully Lowering
   / TYM 503 3pt Lift Arm(s) Not fully Lowering #1
LoneStarLandMan
Pittsburg, Tx
2014 TYM 503
1Already tried the speed drop knob ✔️
2Already checked the draft ✔️
3Already checked the rear hydr lever- position in neutr ✔️
4Already checked tran/Hydr levels✔️
5Already tapped the arms w a tiny sledge 3# ✔️
6Pulled the seat to find there is no access to linkage from there :(
Fel & grapple and all other features function well.
It (3pt lift arms/drop) was working w the bush hog (brush hog) & bouncing around as typical....then decided it does not want to lower fully running or not; when I was taking back to the barn...
Lifts to full position then only lowers back to ~1/3 or ~1/4 all the way down....
~50hp; 4x4; FEL & EA WickedRootGrapple w true 3rd funct installed by TYM dealer
Bumpy field @ med speed....problem solved...:cool:
Any particular reason they would bind up like that
2020 Pratt 8ft S/A Flatbed Tilt Trailer (A56859)
2020 Pratt 8ft S/A...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
100amp Battery Charger (A57454)
100amp Battery...
2012 Nissan AWD Rogue (A56859)
2012 Nissan AWD...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
