TYM T454 cab vs Branson 4720ch
   / TYM T454 cab vs Branson 4720ch
Have you considered a one way restrictor valve that can be placed inline and is adjustable?
I don't think the problem with fine control is the flow rate. It is in the inability to find the point that makes fluid flow and to throttle it at that point with the controls. A restrictor would indeed allow for fine control , but at the cost of losing speed when you need it. I didn't compare things that close. but the hydraulic control valves for the FEL looked very similar on both tractors. The difference appears to be in the mechanics (cables, joystick set-up) that actuate the control valves. On the Branson for a fine controlled curl I have to move the joystick sideways ever so slowly. Nothing happens.... nothing happens (due to slack in the system), and then it suddenly moves more than I want (due to an incorrect leverage ratio).
   / TYM T454 cab vs Branson 4720ch #12
Adding adjustable restrictors has reduced the loader's bucket flop and the jerking of the whole tractor when raising or lowering the boom on the BH. But it's a crude "fix".
I agree that the loader valve or linkage or both could be improved. I still can't curl and raise/lower the loader at the same time. I could do it with the old Kubota I had even though the linkage was worn. It's not a big deal, I have learned to work with it.
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
STORAGE FEES (A52577)
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
