TYM T574 ok at higher altitude?
   / TYM T574 ok at higher altitude?
Some of the valves are too abrupt. It's nearly impossible to raise or lower the boom without jerking the entire machine around disturbingly hard... that valve does not "feather" easily. I added two one way restrictors to the cylinder (two so I can adjust it in both directions) and that made it about 90% better when adjusted so it still moves fast enough. When I curl the bucket with a load it in, the bucket soimetimes slams into the stop and ejects much of the material. I think part of that is due to how the linkage leverage works- the bucket speeds up as it nears the end of its travel. I can get it to work ok some of the time, that valve is not as bad as the boom one. I have another restrictor to add there to see if that will help. Operating three motions at once helps these problems but does not fix them.
Part of this is my lack of experience as a BH operator. But when I got to try out a Kubota mini ex with electric over hydraulic controls I had no problem operating it smoothly and making it do what I wanted (once we flipped the sae/iso switch to make the controls work how I'm used to). It's not really fair to compare a $60k mini ex to a much cheaper BH attachment, but it indicates that the problems I have with my BH isn't just me.
My Branson's loader valve is similar. I find it nearly impossible to raise/lower and curl at the same time. I had no problem doing that with my old Kubota even though it was my first tractor and the joystick linkage was worn out on that used machine. Feathering the loader is difficult but not impossible. (Branson changed how they run the cables on the new models and that may have made an improvement). It's not a huge issue, I can work around it.
I think a lot of this is the quality of the valves themselves. Kubota's known for making especially good ones. Theoretically I could adapt quality aftermarket valves but that's some work and I don't know whose valves are good and whose are not. The valves I have are made by well known companies.
How many hours on the Branson? Do you think the valves will break in over time? Valves are not exactly cheap to replace the whole stack with something of higher quality. Longer levers can help some times. I really like joystick machinery much better than levers. That is one thing that drove me nuts about the Volvo loader. It had three levers that you worked with your right hand for all of the loader functions. I leaned to finesse them, but the joystick in the CAT and the Deere were much better.
   / TYM T574 ok at higher altitude? #22
I got the BH used. It looks like it wasn't used much, which is what the dealer told me as well (it came off a tradein). I have maybe 30 hours on it myself. I bought the 3725 new and it has about 280 hours on it. Neither show any sign of breaking in. It's not like they're terrible, especially after the restrictor mods, but it feels like they could be a little better.
2006 KAWASAKI MULE 3010 DSL UTV (A57192)
2006 KAWASAKI MULE...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2018 John Deere 4052M (A53317)
2018 John Deere...
(INOP) JOHN DEERE 320 SKID STEER (A57192)
(INOP) JOHN DEERE...
2020 Sellick S80 (A53317)
2020 Sellick S80...
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
