Oil & Fuel type of hydraulic/trans oil
   / type of hydraulic/trans oil #1
wendelin
Bronze Member
Oakley KS
JD 185
I think I was told to use John Deere 303 in my fx32d. I am not sure what is in their now. I changed the seal on the pto shaft. Small leak. How much oil would I need if I were to drain all the trans.hydraulic oil.
thanks again
wendelin
   / type of hydraulic/trans oil #2
I can't locate any info on Yanmars website about fluid spec's or fill capacity's. They don't have much info at all on their website. :( Some quick internet searching didn't turn up much either. About the only thing I found is that their is no English owners manual, at least that's what I read. If it does call for JD 303 fluid it shouldn't be to hard to find. Many UTF's on the market meet the JD 303 spec along with the JD Hy-Gard spec.
I have sold UTF to a couple of F and FX series Yanmar owners and the spec they alway's ask for is JD303 so it is probably what is called for. I usually suggest either Special 303 Fluid or UTF that also meets JD303 spec's.
   / type of hydraulic/trans oil #3
thanks again
wendelin
JD 303 or equivelant is the correct fluid. Some here use automatic transmission fluid without any known problems. I don't know the amount as I just fill till it touches the dip stick. I purchase it in 5 gal. containers
   / type of hydraulic/trans oil #4
ATF?? Isn't the Yanmar system a common sump type where it lubricates gears? ATF's have very little EP (extreme preasure) additives that would be found in a UTF type oil.
   / type of hydraulic/trans oil #5
thanks again
wendelin
Buy 5 gal. If you need more, buy more.
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
