tyre question
   / tyre question #1
gregNH
my needs are mowing (field and a lot of finish)
and a bit of plowing ==> 1 acre
what is the best chose R4 or turf
with R4's i think i will damage my turf (a few wet areas)
and with turf tires i think i couldn't plow /forums/images/graemlins/frown.gif
am i wrong???
i hope so
thanks
/forums/images/graemlins/confused.gif
   / tyre question #2
Plowing snow, too? What kind of dirt? How deep? No other tillage work? Turf tires and removable chains might be what you need. A set of chains for the rears will cost a bit.
   / tyre question #3
if it isn't to wet turf tires will be fine
bur i've bigger tires as the tc 40-45da
rear are the same size but the front tires are the same design and size as the rear tires of a tc 24 da (look at the post of tcboomer his rear tires are my front tires and i've 125 kg front weights and a cab ==> a lot of extra weight
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2007 Chevrolet Silverado 1500 Pickup Truck (A56858)
2007 Chevrolet...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
