TZ owners
   / TZ owners
Thanks Rick. I look at the TZ like most compacts. It is a lawn mower with dreams of being a real tractor. My 1920 does some jobs I can't take my TN into but it is useless for much else as it is too light. After the 1920 I no longer have any type of high expectation for the TZ other then to mow the yard but I do know I will probably hook it to a trailer at some point in its life just to shuttle it around.
Ideally I would get a zero turn machine but I have to pay tax on them. The TZ gets me away from the tax and is easier for my grandfather to drive. As for servicing, I will just take it to you if it is that big of a pain /forums/images/graemlins/wink.gif
I am still working with the dealer on numbers. the TZ25 with 60"mmm would cost me $10,800. I think I can drop to the TZ18 and get close to $10k. My one question that hopefully you can answer is this, how much work is there to set up one of the TZ's? My dealer wants $1200 for setup and the other NH fees like freight and surcharges. I do not know how much the actual setup cost is but if I can save $500 by doing it myself (not like we need to mow the yard in a few months now) then I would do so. Is it mostly bolting on tires, hood and MMM and preping the motor or is there more to it?
   / TZ owners #12
</font><font color="blue" class="small">( My one question that hopefully you can answer is this, how much work is there to set up one of the TZ's? My dealer wants $1200 for setup and the other NH fees like freight and surcharges. I do not know how much the actual setup cost is but if I can save $500 by doing it myself (not like we need to mow the yard in a few months now) then I would do so. Is it mostly bolting on tires, hood and MMM and preping the motor or is there more to it? )</font>
What would that do to your factory warranty? I would think it may have an impact on it since you are not an authorized NH dealer. Just something else to think about.
   / TZ owners #13
Wow, I am disappointed to here it. It seems the BX's have the same fan issue, and I know my neighbors bx when lifting a big load or off center load the hood pops up.
   / TZ owners
If it is as simple as bolt on the wheels and hood then I don't think the warranty should be affected. That is something I will worry about later once I know if it is feasible
   / TZ owners #15
Don't look at the TZ as if it were a compact. The name sub-compact is not a misnomer. It is less than a compact by every measure. If you can save $500 by assembling it, have the time and patience, you should go for it. Maybe the dealer has an assembly manual lying around from a previous unit, or will download one for you to peruse prior to committing to the chore. There is a fair bit to it, but it is not rocket science.
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
Generac Generator (A51691)
Generac Generator...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
