Uh oh...milkey white transmission fluid, Landini Trekker 65
   / Uh oh...milkey white transmission fluid, Landini Trekker 65 #1
napabavarian
Napa, Ca
2006 Kubota L3830
I was having some issues with my mid 90s landini crawler and found uppon inspection the transmission / hydraulic oil to be an unconventional color, either prior owner used mayonnaise or there is H2O in the case, I'm guessing #2 is more likely.
I'm not sure how it made its way in, but I'm wondering what the best way to flush it out is and if anyone has any ideas on where it may be comming from, the radiator does not seem to be loosing anything.
   / Uh oh...milkey white transmission fluid, Landini Trekker 65 #2
Some of the TBN members use this mixture as a flush.
1 quart atf ( type f or dex/merc 3 ) to 1g diesel, to 1 pint 90-91% rubbing alcohol. I'll put that into a sump as a rinse. if it needs more fluid for some pickup.. I'll add in some cheap utf or more diesel rinse mix.
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
Saxon Tri Wing Finish Mower (A52384)
Saxon Tri Wing...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
19200 (A50324)
19200 (A50324)
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
