Underground tank leak
   / Underground tank leak #11
Pump the tank out and remove it. Don’t make the situation harder than it needs to be.
Getting someone to pump and remove it may be a huge problem.
   / Underground tank leak #12
Do you know why they used concrete rather than dirt to fill the tank? Is seems dirt would allow the iron to naturally decompose back to the earth.
They probably used a flowable fill mix that’s the vast majority sand with enough cement to get hard. You can’t really fill a tank with dirt unless they cut the whole top out.
   / Underground tank leak #13
Have the owner dig the tank up and removed . I've done a no. of them around here because their no longer allowed. The problem comes when trying to get rid of the tank. The last thing I'd do is get an environmental engineer involved.
I think I'd walk away from that property rather than take on a lot of future costly headaches. Eventually some rich developer will buy the property and greenwash the problem away. I can't afford the lawyers, insurance premiums, and government agency permits, delays and do-gooders.
   / Underground tank leak #14
Be really hard for someone to remove the concrete and start using the tank again.
   / Underground tank leak #15
I don't think I would want to deal with this unless it is proven there isn't any contaminations... once you deal with contaminated soil that's a can of worm that you can't close...
   / Underground tank leak #16
When I was working, we got into something called LUST, leaking underground storage tank. There was some government money involved that is probably long gone. I saw several dug up and some of the surrounding soil woukd usually have to be hauled away. Depending on the size and level of contamination it could be simple or expensive.
   / Underground tank leak #17
I’m not looking to start debate, but I still don’t understand the logic. If it’s a void at the top of the tank that is the concern, pour in the last quarter, over filling, in loose mud. Level out when dry. A fraction of the cost?
There are about 200 gal in a yard of concrete. A train car holds about 9,000 gal. That would require about 45 yards of concrete? That’s 4 and 1/2 truck loads. Even a light grout mix seems expensive.
Well, how much will a Trac hoe, big crane, low boy to haul off tank, dump trucks to haul to fill the void, smoothing equipment, land scaping, probably other things too? Runny concrete sounds cheaper and better.
   / Underground tank leak #18
Yes. The runny cement flows into all the voids if vibrated and never needs compacting. It's under an alley with truck traffic. So they wanted it full and never be able to collapse.
   / Underground tank leak #19
How are you going to pour dirt into a center hole on top of a rail tank car and get it to the ends of the car? Can't be done. The angle of repose won't allow it without someone getting in the tank and spreading it around. Then you'd have to compact it somehow. It would be a slow and tedious labor intensive process.
Your figures are correct. I left after the 3rd cement truck. They said it took 4.5. As I recall, they said each truck had 11 yards.
All they had to do was dump it in and vibrate it until it got to the top and wouldn't take anymore.
This was, as I recall, around 1996-7.
   / Underground tank leak #20
I almost bought a house with an inground oil tank. Two questions..is this a foreclosure and are you getting a mortgage?
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
