dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,619
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I have many hundreds of feet of sched 40 PVC pressure lines, 1", 2", and
4". Most are buried only one foot as backfilling was all manual labor on a
50% slope. I have no doubts that the lines stay cool enough. I have
avoided any exposure of PVC to the air, due to UV deterioration and also
the rare freeze I might get in the winter. My 4" wharf fire hydrant is
reqd to have steel 4" riser, by fire dept requirement. My water system is
all gravity pressure (no pressure tank) and the water storage is 5000
gal concrete with plumbing underneath. I did find out that there are no
22.5-degree elbows made for 4" pipe (only 4" dwv PVC) and gluing up
20' 4" lines is a 2-person job....very tough! All pipes de-burred, cleaned,
primed before gluing.
Finally, if you are subject to inspection, you probably have to do a pressure
test. I had to convince the bldg dept to let me use air, since I could
not fill the pipes with water at the time. It took hours to fill the
pipes with air, but it is important to find/fix leaks BEFORE you backfill.
