Unhappy with X575, etc. ?
   / Unhappy with X575, etc. ?
Thanks robertm and others ! You may have pushed me closer to real tractor land. I'm happy w/ the lawn tractor I have (Kubota TG1860) and probably better off to keep mowing with it and get a larger unit for the heavier application 3 pt. hitch, etc. and not terribly much more out of pocket expense.
   / Unhappy with X575, etc. ? #12
If you have an TG1860 now I would not even consider a Cub or X-series tractor. The TG is a rather capable mower for its class and I think you would be disappointed to find that you can't do much more than you can now.
Thanks Neil for helping confirm that to a tractor greenhorn ! Yes the TG w/ diesel does a great job mowing, but with no diff. lock, 3 pt., etc. mowing is about all I can use it for. Just another good reason for TAS (Tractor Acquisition Syndrome - acronym borrowed from other uses LOL !)
   / Unhappy with X575, etc. ? #14
I am looking hard at the X595. Mowing is not my main reason although I will use it for that. I only mow about 1 acre with the potential to double that if I clear a steep adjacent lot. My main reason for going with the X series is snow removal. I will use the 595 with a 47" 2 stage snow blower as we get over 80" in an average winter (over 200" last year).
I will also use it to remove leaves from my yard with the 3 bag catcher. I would consider the 2210, but it does not have a leaf collection system which can be quickly attached that I am aware of. I don't particularly want a bagger that has another engine.
I don't plan on using a FEL or anything that would sway me toward the 2210, if I did then the 2210 would be the best chioce. I guess that I'm part of the group that JD targeted with the X series.
   / Unhappy with X575, etc. ? #15
I have a 2210 on 3.5 acres, a 200 ft driveway. The power of this machine for serious loader work (with proper counterweight) is phenominal. I suspect the capacity is under rated by the mfr. I have a 72" rb1072 Frontier back blade.(i'd recommend the 60" blade) which is handles well. It's a good value for about the same price as the X595. However I think for anything smaller than my 3.5 acres I might enjoy the X595 esp with the special edition seat. What the other guy said about the ROPS and low tree branches is right, but I trimmed my trees accordingly.
   / Unhappy with X575, etc. ? #16
a BX 2230 would be nice
   / Unhappy with X575, etc. ? #17
after reading a few of the posts - the 2210 is a GREAT machine, and i feel that you an I are in the same boat - i too have 2 acres, and 80% of the time will be mowing.... i too have a long drive way...... 1/8 mile private road with no winter maintance then driveway of 200'..... all this sits on the beaches of Lake Erie PA...... i looked at the 2210 and all its possibilities.... went to my local dealer and found the 4010 - a little larger machine, higher ground clearance, LESS Horsepower/Torque, higer lift capacity..... a little more versatile in those uncommon situations..... my local dealer quoted me a price on the 2210 and 4010 both with the same options fitted for each machine - FEL, 2 stage snow slinger/blower/remover/see it fly, Frontier 3PH mower side discharge...... the 4010 was about 3bills less.
Now that may be my local dealers price, but you have too loot at both machines...
I know the less HP/T can be i hinder, but it is a bit larger machine and can be more apt in different situations - you have to consider your long term future goals - new buildings, pond, landscape, new business, and if a larger machine would foot the bill
hey but is just my opinion - take it for whats it worth - grain of salt.
WOODS TBW144 TURF BATWING ROTARY MOWER (A57192)
WOODS TBW144 TURF...
UNUSED FUTURE CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE CW59...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Metal Bell (A55853)
Metal Bell (A55853)
2010 Ford Crown Victoria Sedan (A55853)
2010 Ford Crown...
