Up to wich angle can I go with a CK20
   / Up to wich angle can I go with a CK20 #21
**** Dirt! :eek: :eek: :eek:
Mine are much less than that, and my stomach can't handle it.
   / Up to wich angle can I go with a CK20 #22
I have the same machine you do. And about the same ditch that you do. The ditch along my drive does get pretty bad at one point. I drive parallel with the drive until the "Pucker Factor" kicks in. Then I back down, pull out, move over and continue to get it done. Take the advice of the others and only do what you are comfortable with. You'll know when it to bad. If your tires are loaded then I'd say keep the loader on and low to the ground. Low range to go slow. And keep it in 4 wheel drive to aid in traction. But be safe!
   / Up to wich angle can I go with a CK20 #23
You gents are forgetting about all the weight of the loader frame above the axle. Believe me...operating on a side slope without that weight is much safer and more comfortable then having that weight on the machine.
If you haven't tried it yet...do so...I think you'd change your minds.
2017 Kubota M5-111D Tractor (A52377)
2017 Kubota...
2010 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2010 UNKNOWN 16...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
