Sorry for my ignorance but what is the flywheel key?
The camshaft gear was the initial problem, which was stripped. Pushrods seemed fine when I had them apart. Lined the two marks up on the camgear and crank gear so timing should be OK? Changed to the new springs with kit and new tappets. Changed governor grear, water pump gear and oil pump gear.
Also the valve lash was just with hand turning over not cranking with key, double and triple checked it so that should be OK as well?
Looking at the tech manual today and I can definitely adjust the governor to proper placement but not sure if that would even cause a carb backfire?
Is it possibly a carb issue?
As always thanks for replies and appreciate the knowledge of you guys.
