*UPDATE* bobcat 753 tilt/lift no light
   / *UPDATE* bobcat 753 tilt/lift no light #1
tbobinac
bobcat 753
Was using the bobcat 753 all day, turned it off for a couple hours, turned it back on but the tilt/lift light is not coming on. Also the bucket now can not be lifted. I checked for codes, none. Not sure what is wrong, just need to know so we can fix. Appreciate any help! s/n 515843577
**Update** so I can't find any exact problems to ours but from watching multple videos and reading discussion boards on different models roughly the same years as ours. I am wondering if it is a solenoid or the actuator. From what I can see most people who have a solenoid issue, get a blinking light on there bcis. I still don't have a light or code. From what I have read people suggest replacing both actuator. Does anyone know if there is a way to test the solenoid or actuator to narrow it down?
   / *UPDATE* bobcat 753 tilt/lift no light #2
Can it travel?
Yep, it moves but bucket drags on ground.
   / *UPDATE* bobcat 753 tilt/lift no light #4
Sorry I should be able to help, have a 773 but no light (must be older than yours). Seems like this stuff is always an inter lock.
Best,
ed
   / *UPDATE* bobcat 753 tilt/lift no light #5
Hi, we have extensive experience in Bobcat repairs. We think you have a problem with the main controller. It is usually on the left side of the bobcat, in the frame. We can definitely help you. You can find us on www.isoscell.com Contact us by phone to give us more details.
20ft Jumper Cables (A57454)
20ft Jumper Cables...
Rotary SM30 Four Post Lift (A57149)
Rotary SM30 Four...
UNUSED FUTURE AUGER SET (A58376)
UNUSED FUTURE...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2013 Genie GTH844 8K Capacity Telehandler (A59213)
2013 Genie GTH844...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
