buckeyefarmer
Epic Contributor
Im not getting one station, has always been tough to get.
Interesting that channel 13 at the same distance and same azmuth (bearing) is transmitting with 20 kw instead of 1000 kw and is projected to have a 12 dBm difference in signal you have marked in blue (good) yet the much more powerful signal from channel 6. Granted it is 48 meters lower in elevation, and the actual RF channel is 50 (UHF) instead of 13 (hi band VHF), but I would have thought it wouldn't have made as much difference. But I guess it does.
It's got 50 times the power?
Yep, according to the chart. 1000 KW ERP. Versus 20KW ERP. So yeah 50 times the power. Of course 50 times the power is not as much as you might think.
Lets look at the S meter on a standard communications reciever. Each S unit (if it used the old standard Collins calibration) is 6 dB
Going from 20 Kilowatts to 1000 Kilowatts is 17 dB of power increase So we are talking about almost 3 standard S units as you would see the signal on a communications receiver. So like S5 to almost S8. Or if a 20 KW signal was S9, the a 1000 KW signal would be 17 dB over S9. Those of you that have operated communications receivers hopefully this gives you some "feel" for this. Remember the dB scale is logarithmic. Those huge gains in transmitter power or antenna gain may not make as much difference on the receiver end as you at first think.
I wonder if the higher frequency is the difference. I lost all of the San Francisco stations when they moved up to UHF a few years ago. Lots of tinkering with various antennas - nothing.Interesting that channel 13 at the same distance and same azmuth (bearing) is transmitting with 20 kw instead of 1000 kw and is projected to have a 12 dBm difference in signal you have marked in blue (good) yet the much more powerful signal from channel 6. Granted it is 48 meters lower in elevation, and the actual RF channel is 50 (UHF) instead of 13 (hi band VHF), but I would have thought it wouldn't have made as much difference. But I guess it does.
SF is over the horizon so apparently all my VHF reception was reflected off the atmosphere, and higher frequencies don't bounce as well.
If you click on one of the channels there's a terrain view at the bottom of the chart. See how that varies for the bad stations vs good that are in the same direction. That may help to see if height will help.
