jejeosborne
Veteran Member
So here is my situation. My '12 f150 got rear ended last week. The hitch, among other things, needs to be replaced.
The factory hitch is rated for 5k or 10k with a weight distribution hitch. Curt sells a class VI hitch for the 150 that is rated for 10k or 12k with weight distribution. I'm thinking if I replace it with the curt instead of oem I can use my dump trailer at the max tow rating of my truck without using a distribution hitch. Am I missing something?
Do you currently have a WD hitch on your trailer? If so, I would continue to use it. You are assuming that just because the new hitch can handle the additional 500 lbs of tongue weight that the frame can as well. Also the WD adds more weight to your trucks front axle that dramatically improves breaking and handling that air bags don't. You are maxing out the capability of your truck and I would want all the help I could get. Hooking up a WD hitch only adds about one minute to the process so I don't see why anyone would choose to avoid it.
