Use of the " in profiles
   / Use of the " in profiles #1
RPM
Platinum Member
There seems to be a bug in the forum software - when you use a quote - " - in the 'Tractor Attachments' line entry in your profile then the forum software truncates your entry.
I have noticed it on several profiles where users have tried to enter, for example, 60" MMM - everything from before the quote on gets truncated.
Patrick
   / Use of the " in profiles #2
I have been stricken several times by the evil and pernicious Profile/Attachments truncation syndrome. I have never known the cause. Brilliant diagnosis!!!!!!! Now, where is Dr. Salk?
   / Use of the " in profiles #3
I noticed this too, but it only truncates when you go back in to edit something. If you type in a whole string of attachments including the " sign and save the profile you are ok. If you go in to say update the hours on the tractor it will truncate your attachment list.
Kevin
   / Use of the " in profiles #4
Re: Use of the \" in profiles
Good catch! /w3tcompact/icons/wink.gif Will try to get that fixed next update...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
Kawasaki NR (A50324)
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
