Use smaller or larger diameter hydraulic hose for implement cylinder?
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I am rebuilding an implement that has a typical 8" stroke cylinder to raise or lower the tool (cultivator). The hoses are 10 ft long and I have always used 1/2" hose in the past because that's what I've always seen. It would be nice to use the lighter weight of a 3/8 hose but I'm not sure how the smaller hose would affect cylinder performance. Any ideas on what would happen if I used 3/8" hose rather than 1/2"?
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #2
The cylinder speed will drop with the smaller hose but the work preformed, force produced by the cylinder is a function of pressure,which will not be affected.if cylinder speed is not a concern you could use 1/4 inch hose, just keep in mind the larger the bore of the cylinder the slower it will stroke because of the reduced flow.
Others may be able to set you right , but I'm pretty sure this is correct.
Hope this helps,
C-ya
Scott
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #3
1/4" hose would work fine for a 8" cylinder.
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #4
It all boils down to velocity of the oil in the lines and that would depend on the volume of the hydraulic pump's output and the cross sectional area of the inside of the line. Have a look here for a basic formula to determine what you would likely need. Hydraulics
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #5
Smaller hose will restrict oil flow and heat it up more. That is an issue with lots of oil flow, like an orbit motor or a continuos moving cylinder.
For a typical 8 inch cylinder not a big deal if you use 1/2 or 3/8. 1/4 inch would work but it might restrict (slow) oil flow so much as to kick out your detent if you have that on your lever - the backfeeding oil would reset the lever to off.
Myself, I find hose smaller than 1/2 inch does not hold up as well over the years, and needs to be replaced more often around the farm.
But 1/2 or 3/8, either would be just fine for your use.
--->Paul
   / Use smaller or larger diameter hydraulic hose for implement cylinder? #6
I agree, smaller hoses will slow cylinder response (could be a good thing) So I would base my choice on how fast I wanted the cylinder to move.
Red Cedar Wood Swing Bench (A55853)
Red Cedar Wood...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
