Used 4052m or new DK6010
   / Used 4052m or new DK6010
MF & Kioti mechanical HST
JD Electronic HST
   / Used 4052m or new DK6010 #12
7,100 ft elevation, high desert.
DK6010SE HST Cab
Weight​
Weight w/ Ag Tires w/ Cab4,043.3 lbs. (1,834 kg)
Engine​
Engine Model3H-TH4C
Engine Gross Power57.7 hp (43 kW)
Rated Speed2,600 rpm
No. of Cylinders3
Displacement111.4 cu. in. (1,826 cc)
Presumably normally aspirated engine; NON-TURBOCHARGED.
John Deere 4052M​
Weight:3770 lbs
1710 kg
Engine Detail
Yanmar 4TNV86
turbocharged diesel
4-cylinder
liquid-cooled
Displacement:127.5 ci
2.1 L
Bore/Stroke:3.39x3.54 inches
86 x 90 mm
Emissions:Tier IV
Emission control:diesel particulate filter (DPF)
Rated Power (EC 97/98):50.8 hp
37.9 kW
Rated RPM:2600
Massey Ferguson 2860E​
Weight:3869 lbs
1754 kg
Engine Detail
Iseki
turbocharged diesel
4-cylinder
liquid-cooled
Displacement:148.6 ci
2.4 L
Bore/Stroke:3.43x4.03 inches
87 x 102 mm
Emissions:Tier IV
Power:57.3 hp
42.7 kW
Rated RPM:2600
At 7,100' altitude a tractor with a turbocharged engine will have close to rated horsepower. Fuel consumption for a turbocharged engine should be about 15% more economical, relative to a normally aspirated diesel engine, at 7,100' altitude.
A non-turbo diesel engine will have a power loss relative to rating of 15% to 18% due to altitude. Fuel economy also less efficient.
   / Used 4052m or new DK6010 #13
Kioti is turbo Jeff not normally aspirated.
   / Used 4052m or new DK6010 #15
I always want a hairdryer (turbo) on a diesel, preferably with charge air cooling (air to air). You get better efficiency and better torque rise as well.
   / Used 4052m or new DK6010 #16
I owned a kioti. If you want to get parts after it’s 10 years old get a Deere or a kubota
   / Used 4052m or new DK6010 #17
Might ask dealers if they would swap tires. Be surprised if R1 ag were not an option on all those models. Again my bias against R4 for serious work.
Do any of these have wheel weights of filled tires.
Any of these have cab? Moving snow in winter cab is nice but they require additional maintenance heat , AC, etc. and get hot in the summer.
   / Used 4052m or new DK6010 #18
I have to say that Kubota is good for parts for older units. Have no issue getting parts or filters or anything for my 2000 and 2002 M9's. Price wise today, I'd wager that Kubota and Deere are running neck and neck, but then everything is expensive today.
   / Used 4052m or new DK6010 #19
You are probably right. Show me a reference, please.
The Kioti specs were copied directly from Kioti's web site. No turbo is specified.
2012 FORD F-650 (A50854)
2012 FORD F-650...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
