Used Aerator -- Good Deal?
   / Used Aerator -- Good Deal? #1
strez
Southern Tier, NY
New Holland TC30 HST 4WD
I saw a used one of these for sale down the road from my house. The asking price is $200.
The implement is slightly used -- rusty from sitting out in the weather, but appears to be in good shape otherwise.
The main question I have is whether or not this type of aerator will work well -- I've read that the 'core' type aerators are the best, because they cause the least soil compaction. This type obviously causes soil compaction when it pushes the spikes in the ground.
For $200, I might just buy it to try it. What do you think? Will this type of aerator cause more harm than good?
   / Used Aerator -- Good Deal? #2
There is nothing wrong with that type aerator as the spikes are close enough to tear up most of the compaction. Yes, the weight pushes them in and as they move forward, pullin out, the ground is puctured. The two types of spikes on there help to prevent so much compaction that it would be a problem. Yes, I think most people would prefer core, but it's not neccessary and the price you state is pretty good. John
   / Used Aerator -- Good Deal? #3
I have one just like it except for the color, I use it in my pasture each fall for over-seeding. Does the one you are looking at have pipe plugs in the end of the drum so you can fill it with water? I fill mine about half full, this really helps penetrating dry ground. If you make tight circles it really breaks the soil which is great for seeding bare spots. I think I paid around $350. new so $200. is not a bad price.
</font><font color="blue" class="small">( I have one just like it except for the color, I use it in my pasture each fall for over-seeding. Does the one you are looking at have pipe plugs in the end of the drum so you can fill it with water? I fill mine about half full, this really helps penetrating dry ground. If you make tight circles it really breaks the soil which is great for seeding bare spots. I think I paid around $350. new so $200. is not a bad price. )</font>
Great, thanks. Yes, there are pipe plugs in the ends to fill with water.
How do you go about overseeding? Simply break the ground with the aerator and then broadcast seed over the broken soil?
You say that you use it in your pasture . . . I would like to use it in my lawn . . . will it be too agressive for my lawn?
   / Used Aerator -- Good Deal? #5
Yes exactly, break the ground up with aerator ( I usually make a criss cross pattern with it.) then hook up the 3pt spreader and overseed & fertilize. The seed normally will find its way into one of the puncture holes. I do use it in the yard too but I have to mark all my sprinkler heads before I get started if I don't the aerator will destroy them if I happen to go over the top of one.
Tim
   / Used Aerator -- Good Deal? #6
STREZ, I have the same one also and if you fill it with water don't forget to empty it before the weather turns cold.
It works very well as far as I'm concerned everywhere I used it grass came up in the pattern put in by the tines.Also you have to lift it to make turns because if you leave it on the ground the tractor wants to go straight! Another thing about it is ,if your trying to aerate bare soil it shouldn't be too damp because the loose soil will end up sticking to the drum(tines)if your doing a second pass over the soil.but that price is a great deal IMO /forums/images/graemlins/cool.gif,Mark..
Thanks to all who responded. I picked it up today for $175. Did one section of my lawn and it appears to work as advertised. I'm not planning on broadcasting any seed, just want to help the soil drain a bit better to try and eliminate some wet areas. We'll see what happens . . .
   / Used Aerator -- Good Deal? #8
</font><font color="blue" class="small">( I picked it up today for $175. )</font> Excellent deal. Wish I could find an equal buy. Congrats, John
Kubota SVL 75-2 Skid Steer (A57453)
Kubota SVL 75-2...
New/Unused Spirit Electric Bicycle (A57453)
New/Unused Spirit...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
Lone Star dump trailer (A55973)
Lone Star dump...
