used aircraft tires
   / used aircraft tires
I plan on having my local mom-n-pop tire dealer do them.. I got 6 of them.. NO WAY am I tackling them myself. Generally that dealer won't mount tires not bought there.. but for this case.. they may make an exception.
On second thought.. i need to check my rims.. i may hav ethe JD bolt together rim halves.. that and tubes may solve some problems..
Soundguy
   / used aircraft tires #12
If you have the bolt together wheels, you can mount them yourself, but I do recommend some type of restraining device, in the interest of safety.
Do you mean when i air them to expand the casing and seat the bead?
Soundguy
   / used aircraft tires #14
When you air them up, after putting the two halves of the wheel together. Use new bolts too. Believe it or not, the bolt together wheels are the most dangerous of the multi-piece wheel designs.
Hmm.. I knew the old style 'split-rims' were widow makers.. but I've never heard of problems with bolt together implement rims.. etc.
Soundguy
   / used aircraft tires #16
I would think the split rims have made more widows than all the bolt togethers ever thought of, but probably because of just shear numbers.
What size are the rims?
David from jax
They look like 15"..though I am not 100% sure..
Soundguy
   / used aircraft tires #18
"Widow Maker" wheels refers to a specific type of multi-piece wheel that has not been produced since, I believe, the mid 60's. These wheels did not have a lock ring. They went together in the center of the wheel and there was no way to tell, for sure, if they were together properly. I have personally seen one of these wheels blow up 10 days after it was serviced. I doubt you will find any tire shop to service these wheels today. About the only application you see them on is old grain trucks. Unfortunately, they are a weird bolt pattern and used, lock ring wheels, of the same bolt pattern are rare themselves and quite expensive.
Lock ring wheels (NOT WIDOW MAKERS) are not inherently dangerous, but should be treated with respect. OSHA regulations require a restraining device for outlets that service them. Even mobile tire service trucks must have a portable restraining device. There is good reason for this requirement. It is, in this case, not your usual BS OSHA stuff. When servicing multi-piece wheels, you should also use an air chuck that locks onto the stem and does not require you to hold it while airing up the tire. A lock ring, under pressure, will hurt your hand if it separates from the wheel. It might even make you say a dirty word.
You can service multi-piece wheels yourself. You just have to use common sense. A chain, wrapped around the wheel, will work for a restraining device, although it won't pass the OSHA requirement. Be careful, but there really is no need to be afraid.
   / used aircraft tires #19
does anyone know where you can buy re capped aircraft tires with tractor tread for front 4 wheel drive tractors, gensco in houston is out right now. agh
   / used aircraft tires #20
Aircraft tires are virtually always caps. The average commercial airliner tire has been capped something like 70 times.
Sorry about the sidebar. I have never seen an aircraft tire with a R-1 tread. You might try St Louis Wholesale. Their number is 800-231-1231.
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A52377)
2013 GMC Sierra...
COMPRESSOR (A53843)
COMPRESSOR (A53843)
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
Generac S/A Towable Light Tower (A52377)
Generac S/A...
