Ortimber
Platinum Member
My guess you haven't seated your rings as yet and the thinner oil just slides by them. No way would I drain it. The 10W rating on oils is for a limited range. If you go to your owner's manual and look in the viscosity chart, you will find that the 10 stops long before you run out of lower temps. Thin oil helps in initial lube requirements at startup. Big dogs in the business of selling equipment and others that maintain it say that the majority of your wear on your engine occurs at initial startup....before the oil gets circulating........this is coming from a thicker is better guy that learned his lesson on his new Ram Hemi.....badass engine.......with WARNING that you had better use 5w-20 or else......course 0 beats 5 but not everybody makes 0 like Mobil 1 does.
At 750HRS on the clock, I’d have to think the rings are seated. Also, the Amsoil isn’t thinner since it’s a 40 wt oil just like the Kubota that was used previously. If you have an oil burning engine, it’s going to do it no matter what oil you use.
