This may all seem random, but just kind of doing a brain dump.
It will run all day and then some on 5 gallons of fuel.
It isn't the most powerful machine in the world, but as long as you keep your expectations inline with the size of the machine, it is a work horse.
I wish the FEL could lift a bit more, but it will lift enough to pick the back tires up (unloaded), so I guess that is the real limiting factor. For all my real "work" it has done what I asked it to. I cleaned all the mud and muck out of the ditch in front of my house, which was 3-4 buckets of mud and silt and it did it without complaint. Just for giggles, I tried to pick the back of my trailer up and it wouldn't do it, but that is probably better than 1,000 lbs. It will pick up my Craftsman rider and Kawasaki 4 wheeler, so it's not helpless, just not a beast. I would put it's capacity at around 500-600 lbs. And, yes, I went around trying to pick random things up.
I haven't removed the mower or FEL yet, but from what I can tell, it's easy.
Another gripe is the lack of parking brake warning light. Just have to get in the habit of stabbing the brakes when you get on it.
Between 4wd, diff lock and FEL, you shouldn't get stuck unless you are somewhere you really shouldn't be.
It is super easy to drive, power steering is wonderful.
I have a problem with getting my shorts leg caught on the H-L-N lever when getting on and off. But, that could just be that I am clumsy.
The turn signals are weird, when you turn the left turn signal, it blinks and the right comes on steady. Vice versa for the right turn signal.
Unless you have small hands, you can't check the oil without removing the side panel.
Headlights are a joke. They use taillight bulbs. If you are planning on running it at night/dusk/morning, plan on having to add lights.
The hood is somewhat of a pain to close, or at least mine is. You can't just drop it, you have to hold it down and latch it. Not a big deal.
The MMM tends to be a bit of a pain to get the clippings off of. I find that the leaf blower works best. They collect in the center and are somewhat hard to get out.
