Backhoe Used Backhoe search for B7200
   / Used Backhoe search for B7200 #1
Spina
Northwest of Boston, MA
B7200
I'm looking for a used BH to attach to my B7200 for some general homeowner projects; walkways, footings for stone walls, drainage, and all the stuff that comes along.
I see various models out there; but, I don't want to strike unless I know I will get a set-up I will be happy with.
Can anybody describe the size, models, and set-up of BH attachments used on a tractor of this size (1200 lbs, 18 hp) and what kind of projects accomplished?
I'm hoping a 3 point hitch set up would be sufficient? I not confident I will find a sub frame kit to match a BH I may find.
I'm thinking it would be best to have a PTO pump to lessen the burden on my seasoned B7200; but, would like to hear others experiences tying into the B7200 system.
Not sure of the max weight of the BH I should expect to hang of the back of the 7200. My reference point is Kubota's recommended BH4672 weighs in at 850 lbs.
I would very much appreciate your inputs.
   / Used Backhoe search for B7200 #2
Sounds like price is a sticking point for you.
BH6000 Woods Backhoe | Cavalier International
$4500
Also the dealer who put on my BH70-X said there were a bunch of left over BH4672's still in the supply chain.
And check 2008 Woods BH6000 Information Haney Equipment Co.
$3K for a new BH seems like a good buy. I have requested a quote and list of other items needed to get a complete set-up.
I'm hoping to get under $2.5K and may need to sell a belly mower to get there. Has anybody put a BH6000 on a B7200?
Any words of wisdom for using a Woods 750 3 ph BH with my B7200 for my typical home owner activity?
   / Used Backhoe search for B7200 #8
Thats 1 word. Maybe 1.5
Sorry
Do Not
There's 3 words.
Search the forums, especially attachments, although I've not seen pictures of a tractor "broken in half" there seems to be a lot of theory that on a SCUT (or generally most tractors under 30hp) a backhoe the size of the 750 can damage the tractor. And I only remember 1 poster saying he did it, but treated it very gently.
My 70BH-x required a fair size sub-frame to make a "4 point" hitch.
You might be able to do it with a special toplink, but then again, might not.
A smaller backhoe might also be doable.
Apparently Woods makes a subframe to attach the BH70X on the B7200HST only nothing for the gear drive B7200. And nothing at all for the BH6000.
Could somebody provide other sources for subframes?
I have found Kubota literature that identifies the BH4672 as a compatibly implement for the B7200 and weighs in at 850 lbs. Does anyone know if Kubota has a subframe for this mount or is it a 3PH?
   / Used Backhoe search for B7200 #10
re:BH4672,
It's a probably "4 pt" mount.
Check with Messicks. I know they made one for the B7610, my dealer was going to get one for me if I went with the BH4672.
/edit - but isn't that hoe a little large for the B7200?
/edit - another link about broke back tractors http://www.tractorbynet.com/forums/buying-pricing-comparisons/32962-tractor-can-break-half.html
   / Used Backhoe search for B7200 #12
I agree that using a 3 point mount backhoe on this tractor would be a mistake. However I have a Woods 750 using a subframe mount on my Kubota B7100. I have many hours on it and have had no problems at all. The subframe mounts into a U shaped reciever under the rear axle and the front of the subframe bolts to the FEL frame under the center of the tractor. Easy to put on and off and will dig some amazing stuf for a tractor of this size.
I did get in touch with the craiglist guy. He sold the B7200. It had the B4672 on it with a subframe; all Kubota.
The CADDIGGER looked interesting; but its a 3PH arrangement. So far I haven't hear of anybody mounting a BH to a tractor this size in a 3PH arrangement and plenty of advise telling me not to do it.
So far I only know of one Manufacturer making a subframe for this tractor; Kubota. And the B4672 is the only BH I have heard of someone putting on this tractor.
Again Woods told me they have no subframes for the B7200.
Does anybody know of another options?
   / Used Backhoe search for B7200 #14
There was at least one guy on here who fabbed up his own subframe. You'll have to do a search though being as I can't remember who it was!
   / Used Backhoe search for B7200 #15
I'm with Danno. Can you weld? There are actually several members here that have made their own subframe......... just a matter of money / ability. A few years back i made one to mount a Woods BH6000 on a mid-eighties Yanmar. I had a local steel fab shop cut most of the materials and punch some holes, but I did all the fitting and welding in my driveway. I wouldn't claim it looked like a current factory subframe, but it was plenty strong, and pinned onto the tractor easily. I would guess I had about four hundred dollars in materials. Even if you paid a fab shop to do everything..... perhaps you could find one who could do the whole job for not much more than buying a subframe??
207280 (A52708)
207280 (A52708)
pressure washer, and trailer (A56859)
pressure washer...
Deere 333E (A60462)
Deere 333E (A60462)
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
