used front end loader for jd 2240
   / used front end loader for jd 2240 #11
rdbigfarmboy
You brought up a good point about side rails. Not all JD utility tractors came from the factory with side rails. Side rails need to be installed if not already installed before adding a loader.
   / used front end loader for jd 2240 #12
With the 2030 and 245 loader, I have the optional HD front axle, and 11-15 front tires. Even with loaded rear tires and 4 110lb wheel weights I have to put on rear implement for real heavy loads. I have lifted logs so heavy the grapple would not curl back.
If he does not have the HD front axle, I would not recommend a 245 loader. A great loader, but too big for that tractor.
   / used front end loader for jd 2240 #13
If your 2240 has a straight front axle, you can go heavier on the loader. However, most were not straight axle, also the 520 loader will fit as well.
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
