used front end loader for jd 2240
   / used front end loader for jd 2240 #1
mhtmtree
Dover Plains, NY
jd2240 jd4200 jd310b jd450c ASV 4810
looking for a loader for my 2240. Any ideas on where to look and approx. cost
   / used front end loader for jd 2240 #2
Where are you located? I'd guess $2500-$4000 depending on the loader.
JD loader models that will fit are 145,175,48 & 245.
Thanks for the reply. I am located in Dover Plains NY. I have a tlb and skidsteers but wanted to get more use out of this machine.
   / used front end loader for jd 2240 #4
How about the 146, too?
AKfish
   / used front end loader for jd 2240 #5
My vote is the JD 175. Try tractorhouse or machinefinders
   / used front end loader for jd 2240 #6
My neighbor's got a 245SL on his 2640. Now, that's a LOADER! :D
AKfish
   / used front end loader for jd 2240 #7
AKfish
I have one on my JD 2030, might be a little too big for a 2240
   / used front end loader for jd 2240 #8
It is a pretty big loader... he put on some real big front tires and rims to handle the added weight!
Not sure of the difference in tractor size/frame size between the 40 series, either.
Come to think of it, though - he was using a 2240 (50hp) on a JD 336 baler and using his 2640 to work a big round baler - in the same hay field.
The 2640 was definitely a bigger machine.
AKfish
   / used front end loader for jd 2240 #9
Basically the frame sizes are the same. Of the 2 tractors you mentioned the 2240 is just shorter wheelbase because it has a 3 cyl engine vs a 4 cyl engine in the 2640
   / used front end loader for jd 2240 #10
I would go with the lightest loader with the shortest frame. meaning the load is carrier closer to the tractor. you might have trouble reversing or spin a bit with a big loader on your tractor. Not to turn you from green paint but westendorf has some very good loaders probably a bit heavy for that tractor. Bushhog something like a 2425 or 2426 is a decent low end loader, fairly cheap to buy 1500-2000 or so and can bolt to the side rails and front end.
   / used front end loader for jd 2240 #11
rdbigfarmboy
You brought up a good point about side rails. Not all JD utility tractors came from the factory with side rails. Side rails need to be installed if not already installed before adding a loader.
   / used front end loader for jd 2240 #12
With the 2030 and 245 loader, I have the optional HD front axle, and 11-15 front tires. Even with loaded rear tires and 4 110lb wheel weights I have to put on rear implement for real heavy loads. I have lifted logs so heavy the grapple would not curl back.
If he does not have the HD front axle, I would not recommend a 245 loader. A great loader, but too big for that tractor.
   / used front end loader for jd 2240 #13
If your 2240 has a straight front axle, you can go heavier on the loader. However, most were not straight axle, also the 520 loader will fit as well.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
iDrive TDS-2010H...
