Model Overview & Specs
Chassis
Dig Depth 2 ft. flat bottom: 91.0 in. (2311 mm); 8 ft. flat bottom: 69.3 in. (1761 mm)
Reach 42.0 in. (1067 mm)
Bucket Rotation 182 deg.
Swing Arc 180 deg.
4-point mount quick-attach convenience combined with rigid mount sturdiness
2-lever control provides smooth, easy operation
Powered by the tractor hydraulics
Not compatible with
B3030 HSDC cab model tractor
Compatible with front loaders and mid-mount mowers (performance matched system)
All hoses are routed through backhoe arm
Sub-frame doesn't interfere with the mid-mount mower linkage, there is no need to remove the sub frame
Specifications
Application: B2630HSD, B3030HSD,
L2800,
L3400
Transport height: 80.4 in. (2042 mm)
Stabilizer spread transport: 51.8 in. (1315 mm)
Ground clearance: 12.9 in. (327 mm)
Overall width: 54.9 in. (1394 mm)
Maximum digging depth: 92.2 in. (2341 mm)
Digging depth, 2 ft. flat bottom: 91.0 in. (2311 mm)
Digging depth, 8 ft. flat bottom: 69.3 in. (1761 mm)
Operating height, fully raised:: 120.1 in. (3050 mm)
Loading height: 81.8 in. (2077 mm)
Loading reach: 42.0 in. (1067 mm)
Reach from swing pivot: 120.5 in. (3060 mm)
Swing pivot to rear axle center line: 38.4 in. (976 mm)
Bucket rotation: 182 degrees
Stabilizer spread operating: 67.6 in. (1717 mm)
Angle of departure per SAE J 1234: 18 degrees
Leveling angle: 10.2 degrees
Swing arc: 180 degrees
Digging force using bucket cylinder: 3339 lbs. (1514 kg)
Digging force using dipperstick cylinder: 2097 lbs. (951 kg)
