Used Massey Ferguson Gc 2610 parts.
   / Used Massey Ferguson Gc 2610 parts. #1
renegade1958
Boundary Creek, New Brunswick, Canada
GC2610 TLB
Hello everyone. I am looking for a source for used parts for my Massey Ferguson GC2610 tractors. Just took the rear PTO shaft out to replace the bearings and I found that I had major bearing failure and as a result have a broken transmission housing where the bearing sits so as a result I am going to be lookin g for a transmission housing. Any help would be greatly appreciated. Thanks
   / Used Massey Ferguson Gc 2610 parts. #2
Now that will be a bit of a pickle...
Can you get us a picture where it cracked?
Also you can try to get it welded and then grind the required hole for the bearing...
Otherwise finding a donor will be quite the feat...
   / Used Massey Ferguson Gc 2610 parts. #3
You'll need to double check my findings... Go here Object moved to confirm the part number for the housing. It appears that housing was used on 4 different models, but even at that, only found one, doing a quick search http://www.tractorhouse.com/list/partssearch.aspx?partnum=4264907M2&pst=starts.
However, I went directly to Wengers site, and ran the part number, but got no result. I guess a phone call would be your best bet, to check. You could at least get a price, and compare to having it repaired, if that is possible, and cost effective.
2015 Ford F-350 Cab and Chassis Truck (A53422)
2015 Ford F-350...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
