Used my old Dearborn two bottom plow for first time today.
   / Used my old Dearborn two bottom plow for first time today. #11
I would suggest going as far as making a jig out of 2x10s or trying to get real precise as to fine tune with 1x10s.
But tossing down a 8" cinder block and driving up on it, is pretty easy and straight forward.m makes it easy to adjust the side and fillings so all shares are evenly on the ground and flat.
Not an exact since or a set-it and forget-it method. But gets pretty close. There will always be fine tuning in the field til you get desired results.
But the block makes it easy to adjust the side link since the tractor is on an angle, and the goal is to have the plow flat on the ground, you aren't fighting gravity with the adjustments.
Although I have TNT now and am eager to get out the 3-bottom plow I just picked up last month. The hydraulics should make it easy to setup, and easy to adjust on the fly
   / Used my old Dearborn two bottom plow for first time today. #12
Blocks: a few different lengths of 2x6 laid on top of each other with each board set in a few inches to give a slope to drive up.
John Deere Gator Utility Cart (A50324)
John Deere Gator...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
Two Post Car Lift (A50120)
Two Post Car Lift...
