jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 20,387
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
The wheel width on a TC35DA with R4s is about 68" wide. A 60" implement on the 3PH will NOT cover the wheel width. It seems to me that the TC35DA would be a good choice for all the chores you mentioned, but you will need 72" implements on the 3PH to cover your tracks. The most common loader bucket on these tractors is also 72" wide. If you go and inspect that TC35DA tractor for $15k, you just might have the best solution for your needs. It's surely strong enough to do a good job of cleaning barns. I'd think even a smaller tractor would do that well. By the time you get a loader on the front and a scraper blade on the rear of the TC35DA, it's quite long. You can raise the bucket to make maneuvering easier, but then you have to consider that the overhead in the barn needs to be greater than the loader's 110" high reach. The HST and power steering make this tractor a dream to use and manuever in most circumstances. Back and forth loader work is where it will excel.
EDIT: Down in the NH forums, DoubleL just bought a 3040 HST tractor. That's the same tractor as the TC40DA. He posted pictures of his wife operating that tractor on the day it was delivered. I don't know many tractors that are as easy to operate as the TC35DA. If you get it, it will be easy for you and easy for you to teach anyone else to use. That's a big plus.
