used power pole for fence post
   / used power pole for fence post #11
</font><font color="blue" class="small">( Would it be worth buying a chain saw and renting a loader? A 6"-8' fence post costs about $14. If this is as long-lasting and strong as used utility poles, I may not quite justify the expenses of chain saw and loader. What do you think?
)</font>
well first off i dont know how ya could live in the country without a chainsaw, so i would go buy one of them right away, and why on earth would you rent a loader, especialy if your gona cut them up anyhow, i can easily load a 9 ft length of utility pole into a pickup by myself, get one end in and then push the other end in, with two people you would have it even easier. with a comealong and some planks i have even loader full length poles into my dumptruck a couple times, i wouldnt even consider the expense and trouble of a loader, one other option is get someone with an automotive rollback truck, they could slide on a bunch of them and deliver them pretty reasonable. but again for fence posts your gona need to cut them anyhow so just load them in a pickup. now that being said, i dont think i would use them for fence posts, i use regular pressure treated landscape timbers for fenceposts, about 3 bucks each, and i use utility poles for corner posts, they work great
   / used power pole for fence post #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( .. why you need a loader?
Soundguy )</font>
When I called the power company, they said people bring in a loader, grappler, etc to lift the poles. I assumed the poles were too heavy to lift manually. )</font>
They may not allow you to cut them on-site for liability reasons? Otherwise cut them there, & easy enough to load up with 1 or 2 people.
You can load them on a trailer by yourself, uncut, but it takes a good back & maybe a rr tongs or the like. Or an electric winch on the trailer. Or several good friends who owe you a favor.
Depends on how many you will be getting.
A loader will sure make it easier, but you don't need to physically lift the whole pole - just an end, & get it sliding....
More than one way to skin a cat.
--->Paul
   / used power pole for fence post #13
Yep.. let mechanical advantage be your friend.
A timberjack could be used to get an end up.. then back the trailer under, then start sliding.
Soundguy
Thanks for the tips. In about 2 weeks, I will know how heavy they are. You folks seem to know so much about tools and equipment. I don't know what timberjack is. I have to google it.
One related question if I may. What size chainsaw should I buy? Is 16" good enough for general purpose? Thanks again.
By the way, according to Customer Service, people show up with chainsaws and the loading equipment. Apparently, they cut up the poles in situ.
   / used power pole for fence post #15
Oh no!!!! A chainsaw question!!!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Yep, 16in is dandy for a general use saw. Most people get to excited and go to big. A 16 in bar is real easy to handle and lighter.
Since you really dont seem to use a saw much, a regular Poulan (green) or Homelight should do you fine.
   / used power pole for fence post #16
<font color="red">The creosote splinters will work their own way out, unless you get the 3-4 inch type.</font>
Sounds like you have experience with those. Personnaly, I only burned a pole ONE time /forums/images/graemlins/frown.gif
   / used power pole for fence post #17
I flew away from the two I came off of and jumped from the one I was riding down, I only hit air on the way down /forums/images/graemlins/grin.gif. Never burnt one all the way down. The little splinters you get in your forarms on a day to day basis always worked there way out on there own. I got to see a guy get a chest full of wood though. Docs had to pull them out.
Hey, I gotta ask. Is the mexican restraunt still there on the left as you come into Oak Harbor from the south??? They made the BEST picate sauce fresh at the bar and the food was great. I was thinking about it the other day when I took the wife out to a Mex place that everyone here said was real good. (It was ok)
   / used power pole for fence post #18
</font><font color="blue" class="small">( I don't know what timberjack is. I have to google it )</font>
A timberjack is a hand tool with a wood handle, and then a stand at a 90' angle tot he bottom of the pole. The a large jaw with a tong that pivots on the jaw wher eit would attatch at the pole. Say you have timber ont he ground ( tree.. telephone pole.. etc.) and you want to cut it with the chainsaw.. you don't want the bar cutting into the ground, so you lok the jaw around the log.. handle is pretty much pointing verticle.. then you rotate the handle down, this rolls the log over, using the logs own weight to hold the tong onto it.. kinda like a skidding tong.. Anyway. the whole thing lays over until the log is propped up ont the metal 90' leg of the timberjack. This puts the log 8-12" off the ground for cutting.. or.. backing a flatbed trailer up to so you can set it on the edge.. etc.
I may not have described that well. .but I've seen a few of them and that is the jist of it. i think northern tools sells them.. might find a pic there.
Ok here's a pic of one from northern.. they sell them from 29$ to 42$
Soundguy
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2015 Kubota L2501D (A50120)
2015 Kubota L2501D...
