Farmwithjunk
Super Member
777777 said:Hi,
So if you were looking to buy a used truck, that would not break the bank, to tow a tractor on trailer that would weight " up to " 7000lbs, what would you look at. Year doesn't really matter but let's try to keep it under 1999 model year to try and keep more reasonable in price. This would be a tempory solution for maybe 18-24 months and then could upgrade
Issues are price, safety, ability to tow. Price is almost as big an issue as safety.
Make is not an issue.
Gas or diesel but diesel ups purchase price but a bunch and gas could be serviced by me or my buddies.
Consider would start out towing up to 2000 miles once per month, after a few months up to 2000 miles every 2 weeks.
Do you start looking in the " 2 " series like Chevy 2500, Dodge 2500 or Ford 250 ?
Or do you look at the "3" series ? Duallies ( if yes why ).
When you start looking at pickups, you see that then Chevy 2500 and 3500 series seem the most inexpensive. At least less expensive than the Dodge or Ford.
Any thoughts ?
After reading all this thread, I had to throw my $.02 worth in. I've been dragging tractors around on trailers behind pick-ups for a long time. I've learned a few lessons along the way.
One is, get as heavy duty a truck as you can afford. Don't try to "get by". Forget 1/2 tons right off the bat. Waste of time. Waste of MONEY. All the "I haul my tractor with a mini-truck and never have any problems" responses are fooling themselves. They haven't had their once in a lifetime catastrophic failure YET, but it's coming.....soon more'n likely.
Duallies don't carry that much more CARGO CAPACITY. What they DO carry is a saftey factor of more tires under the load, more STABILITY at speed, and more "respect" from any law enforcment officers who may at some point, be examining your rig.
Longer trucks have more stability at speed. In MOST cases, shorter framed trucks will have more weight rating, but that's not carved in stone. A short bed will limit placement of a gooseneck hitch somewhat compared to a longbed, but once again, not carved in stone.
Diesel/manual transmission pick-ups are THE WAY TO GO for heavy towing. BTDT, got the tee-shirt. Gassers and automatics will suffice, but over the long haul, get a diesel. Back it up with MANUAL tranny.
Most newer trucks are available with factory towing packages. GET THAT..... They generally consist of transmission coolers/extra engine cooling capacity (including engine OIL coolers)/heavier brakes/suspension components/pre-wired lights and brakes/ect. Cost savings is only a part of that equasion. Having factory engineered components rather than shadetree installed mix-match of parts is worth its weight in gold.
Brakes on 1/2 ton trucks are their biggest liability when towing. They're only marginal at best when approaching tow ratings. Trailer brakes aren't designed to STOP a load by themselves. They're intended to ASSIST the trucks brakes. The truck is doing (if set up correctly) 60% to 75% of the stopping. A big stout trailer behind a marginal pick-up is suicide in my book.
When planning out a tow rig, you don't set up for 99.9% of your hauling needs. You set up for that .1% of the time when you need to make a panic stop or deal with unexpected highway conditions. YOUR LIFE and the lives of those sharing the highway with you depend on your good judgement.
I've down-scaled my farming in the last year. I still do some "hobby farming" though. I haul two different tractors from time to time. Usually they'll have some sort of implement hanging on them. My "cargo" will usually be in the 7000 to 8000 lb range. That's on a 14,000 GVWR gooseneck trailer. I have one truck of my own, and access to my sons. I have an '04 Dodge 2500 4WD, 4-door, long bed, HO Cummins (Automatic tranny.... I broke my own rule on this one. Old age, sore knee and clutch don't mix well) Sons truck is '05 Dodge 3500 dually, 4WD regular cab, long bed, HO Cummins/6-speed manual shift, both with B&W "Hide-A-Ball" hitches. I consider either of these trucks just barely enough to be safe in most cases. Anything LESS is just kidding ones self.
If yo're talking about towing a lot, and/or over long distances, all these recomendations become REQUIREMENTS. Anything less is foolish.
