Niles --
Last fall we had our front porch expanded in order to build a sunroom, and had the old sidewalk removed at the same time. The guys who did the work brought a Terramite T7 (Kubota D1005 engine). The Terramite has significantly stronger hydraulics than the
BX23, but the
BX23 should be able to handle the job anyway.
Here is their method:
They backed up to the sidewalk so that they could reach across it with the backhoe, then used the BH to lift the opposite edge. First they tried lifting and dropping the edge to get the concrete to break. This stuff was 45 years old and tough! Dropping it didn't work, so they gave the youngest guy on the crew a big sledge hammer. /forums/images/graemlins/crazy.gif While holding the edge of the sidewalk up with the T7, the hammer operator smacked it as many times as needed to get it to break. They continued with this, lifting sections and breaking them up with the hammer.
I had them dump the rubble out behind my garden, and plan on using it as riprap when I get around to fixing the washed out dam on the pond in the old hog pen. A few of the pieces are about three feet long, but most are roughly one foot square. That took a bit of bashing, but made it easy to pick up and move with the Terramite's FEL.
By the way, my sidewalk was about five inches thick, and I figure the pieces run about 60 to 70 pounds per square foot.
If you do this, wear the appropriate PPE!!! Safety glasses for sure, and whatever else you think you need -- face shield, hard hat, etc.??? /forums/images/graemlins/shocked.gif
Here's another tip -- I knew better, but forgot. When they came to place the new concrete, of course they had to wash out the truck when they were finished. I didn't designate a wash-out area, so of course they used my gravel driveway! /forums/images/graemlins/blush.gif After the stuff cured I tried breaking it up with a sledge hammer, but didn't have any luck at all. Then I got smart and brought out the
BX23 and used the BH to pull up the thin layer of concrete on top of the gravel. Once it was loose it was a simple matter to walk around and break it up with a little two-pound hammer. Of course, it would have been even simpler if I hadn't let them do that in the first place, but then I wouldn't have gotten the extra BH time! /forums/images/graemlins/laugh.gif
