Using a Chain Harrow?
/ Using a Chain Harrow? #1
Starboard
Dallas, Texas
Howdy, guys. I am a newbie here, so ya'll go easy on me, will ya?
I bought an 8' chain harrow when I got my new John Deere 3038e. The harrow works great with the teeth down, even pulling it behind a disc. My problem comes in flipping it over to use it without the teeth down. Not sure what that thing weighs, but I can't lift it on my own. How do you guys do it?
I first thought about picking it up with a chain wrapped around the bucket. The thought was I could kill two birds with one stone and not only flip it over, but get the trash out of it at the same time. Instead I decided the easiest thing was to just put a chain on it and pull the front back over the top. That didn't work out so well. Now I have a tangled mess. Help!
/ Using a Chain Harrow? #2
I have a much smaller one that I can manage, but they are difficult to turn over. Northern Hydraulic does sell a 3pt lift for the different sizes of them pretty cheaply, but I would think the loader with a chain from both sides would work too.
/ Using a Chain Harrow? #3
Consider having a couple of hooks welded to the bucket, would make this process a lot easier. With a lot of trash you may find yourself cleaning the harrow often.
Steve
/ Using a Chain Harrow? #4
should be no problem with a loader.. just chain and lift it up and spin around and lay back down.
soundguy
/ Using a Chain Harrow? #5
My eight footer is actually two pieces - so I separate 'em and do the fold/roll over thing - works pretty well.
/ Using a Chain Harrow? #7
seems like the least manual labor involved.. etc.
soundguy
/ Using a Chain Harrow? #8
I've got a 8' pipe (2") on the front and back of mine and use a 3pt boom to carry it around. Flipping it over or shifting it front to back is no problem with the boom.
/ Using a Chain Harrow? #9
When I got back at it I found that this chain harrow was actually in four sections. The sections were wired together latterly with very light wire. I removed those little wires and separated the sections. It was then easy to handle. I did use a chain to suspend the front sections from the bucket to work on it.
Thanks to all for your ideas and help. Now, I need to figure out how to store the thing off the ground so that I can get to it when I need it.
/ Using a Chain Harrow? #11
if you got a board fence, could hang the individual sections from it.. that or make a sawhorse.. or similar arangement out of a couple fence posts and a 2x6 and hang them over.
soundguy
/ Using a Chain Harrow? #12
If yours is 5/8" steel like mine, don't worry about storing it on the ground. Mines 10 years old, and is parked right in the pasture when not in use. Hasn't hurt it a bit.
//greg//
/ Using a Chain Harrow? #13
that's wher emine lays.. and it's one I inherited from my stepdad.. it's oldold.. and still fine with a light rusty patina. I store it wherever I unhitch it from the tractor after pulling it..
soundguy
That sounds great Greg and Soundguy. Makes sense to me. If it's good enough for you, it is good enough for me.
That is what I am going to do with it, let her lay. Thanks.
/ Using a Chain Harrow? #15
Just don't hit it with your batwing mower after your friend borrows it and leaves it inthe middle of the pasture, vs along a fence.. it makes a terrible clatter! ;)
soundguy
Invoices (A63116)
Invoices (A63116)
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2022 Polaris 1000 Ranger (A64047)
2022 Polaris 1000...
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
