using a hydraulic adapter on a ford 4000SU tractor to power a front loader
   / using a hydraulic adapter on a ford 4000SU tractor to power a front loader
One of the things that excited me about the quick attach loader was not having to carry it around all the time. I am told that the tractor pump is really too small to do a good job of running the loader and thought about installing a separate pump. However I grew up with an old 861 with a one-arm loader that worked off the system hydraulic and it seemed fine at the time so I thought I would at least try the tractor hydraulic before I went to a separate unit. From the knowledge I gained on this forum it seems the problem is connecting a PB adapter to a non PB remote valve. I can either do away with the adapter or get a new control valve. Probably he best route is a new PB remote valve. If I am on the right track, how about the joy stick valves? Would I be better off attaching the valve to the tractor and having quick connect couplings to the loader? that way the hydraulic system is not changed when I take the loader off. What do ya'll Think?
   / using a hydraulic adapter on a ford 4000SU tractor to power a front loader #13
The joystick valve should be a good selection.
The speed of operation is dependent on the GPM's.
A fan belt pump of a PTO pump would also work.
With the loader off, just jumper the P and the PB, and everythng should be back to normal.
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
LOT LOCATIONS (A54313)
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
