Using a turnbuckle for a top-link?
   / Using a turnbuckle for a top-link? #1
Eldubya
Vancouver Island BC
Kubota B7800HST
Bent the bejeebers out of my adjustable factory top-link, and am waiting for a replacement, but in the meantime...
Anybody ever use a galvanized turnbuckle in place of the standard top-link?
I suspect it's going to be quite brittle and prone to snapping? But it just might work! Definitely cheaper than a OEM.
   / Using a turnbuckle for a top-link? #3
I would think a turnbuckle would be dangerous to use instead of the top link. On a box scraper you will put a lot of pressure on the top link when back filling. And if you already bent the top link how will a turnbuckle hold up. I have spent enough time in emergency because I tried a short cut or tried using a substandard part. Top link is designed for dynamic force, turnbuckle is designed for static force.
   / Using a turnbuckle for a top-link? #4
A toplink is really just a glorified turnbuckle. If you can find a VERY sturdy turnbuckle, then it should work in an emergency as a temporary fix.
Some folks use a chain as a toplink and, depending on what implement is being used, that may work. But bending a toplink indicates that it likely was used in a compression situation so a chain would not work for such an application.
Tractor Supply carries them at a reasonable price:
Tractor Supply Co. - Enjoy searching:adjustable top link
Bent the first one using it as the brace on a mechanical thumb on the back-hoe. (curl in has a LOT of power!)
The Turnbuckle will just be temporary, but I think I will carry one around as a back up.
   / Using a turnbuckle for a top-link? #6
A steel turnbuckle should be OK. A junky cast mystery-metal one could be dangerous.
However, adjustable aftermarket 3rd points might be cheaper then a good turnbuckle.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Bobcat A770 (A60462)
2007 Ford E350 (A55973)
2007 Ford E350...
2018 HINO SA (A58214)
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
