Using an angle grinder. Dumb questions.
   / Using an angle grinder. Dumb questions. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I bought an angle grinder a number of years ago. It is a good quality Dewalt. I bought it to shape up my rotary cutter blades and it does a fine job. On a couple of occasions I have replaced the grinding disk with a cutting disk to cut metal with. It seems like it was a generic Dewalt multi-purpose cutting disk. Much thinner than the grinding disk. It seems to do okay but the last time I used it the disk disintigrated. I had on safety glasses and gloves and the disk parts did not hit me.
I know nothing about these tools or proper types of disks etc.
So, what do I need to know about using an angle grinder as a cut-off tool? Are some disks better than others? Certain disks for certain types of metal? What made mine fly apart? Is heat an issue? It didn't seem to be that hot. Is it common for them to come apart?
   / Using an angle grinder. Dumb questions. #2
I have never had one come apart , I'm sure you wasn't doing this but you should not use a cutting disk like a grinding disk like grinding on it's face . The only thing I can think of as you were deeper in the cut it may have bound up which made it unstable and break appart . Thank goodness you had on some protection . I'm sure there are better grades of disks , like maybe not buying ones made in China for example .
   / Using an angle grinder. Dumb questions. #3
Grinders aren't made to tight shaft bearing fits, so a grinder's shaft will have more play to allow expansion of the bearings and shaft from heat during long grinding sessions.
That being said, running a thin cutter wheel designed for a precise intermittent duty tight bearing shaft assembly, runs the risk of side loading the cutter from what you would see as 'wobbble'. At least you wore eye protection. That's a good thing.
   / Using an angle grinder. Dumb questions. #4
Could have been fractured to start or inadvertently by a side bump ... or bounced or pinched in the groove at speed. Yes, the cutoff wheels do disintegrate occasionally, whether glas reinforced or not. Be sure the mandrel is not stressing it when mounted in the grinder. Always stay out of line with the direct tangential motion of the disc and you will pretty safe. The grinder guard can be adjusted.
larry
   / Using an angle grinder. Dumb questions. #5
Another thing to check is what speed (RPM) the disc is rated for. Maybe it was rated for 10,000 RPM and the grinder runs at 13,000 RPM. Disc wouldn't last too long at that RPM. Cut off wheels are pretty fragile too. If it caught or you put too much pressure on, it doesn't take to much flex for it to fail.
   / Using an angle grinder. Dumb questions. #6
I buy all my disks at harbor Freight. I have had the disks disintigrate, and also fly apart. If you look at the way they are made its suprprising that they hold together at all. I just consider it the "cost" of grinding. If you pinch or bend a cutting disk or for that matter a grinding disk, it's going to shatter and it's probably going to hurt and leave a mark. . . . John
   / Using an angle grinder. Dumb questions. #7
larry
x2
Expect the worst from those things. Always use the grinder guard and safety glasses or a face shield. Do not lock the grinder on when using the cut off wheels. I have been stuck with the thin disk fragments and it's not fun.
Thanks guys. I think a face shield would be a good investment. The tool scares me a bit and I don't like using it but there are certain things that it does best. I think I'll look into higher quality disks too. And it was kind of strange, if I remember correctly it didn't actually disintegrate it mostly broke off in two large pieces that did not fly away with that much momentum.
Robert, good advice about the not locking it on...........which reminds me of another recent power tool mishap............
I was using a rather powerful hand drill with a wire brush on the end to clean up an old brass mailbox. The drill is too much drill for the job and I have smaller, lighter drills that I should have been using. Anyway, I had it locked on so I didn't have to hold the trigger down. At one point I was in an awkward position and leaned over and the wire wheel caught in the right sleeve of my short sleeve shirt. As you can imagine it bunched the shirt up and then dug into my arm. Then, the shirt bunched up so much it stopped the wire wheel and so the drill itself started to spin. It had the hand grip in it and it proceeded to beat the dickens out of me until I got my hands on it at which time it ripped my shirt clean in two. I was then able to throw it on the floor and unplug it.
I had a huge bruise on my little bicep with a good sized divit that the wire wheel dug out. So there I was, blood running down my arm, huge bruise already forming, half my shirt torn off, and bruising forming where it hit me in the face, ribs and belly. And all I could do was laugh. The first thought that came in my head is that I wish I could have seen it on video! The next day I felt and looked like I'd done a round with the champ.
Moral(s). Use the right tool. Don't lock power tools in the on position unless necessary.
   / Using an angle grinder. Dumb questions. #9
Never use a chipped disk.
Cutting wheels should NEVER be used to grind. (There are a couple cutting disks made that are able to be used as a thin grinding/cutting wheel, but those are rare, like the Walter Pipefitter and HP Combo)
Watch for bends in the wheel. Bends will crack the reenforcement. This usually happens when a grinder falls to the ground or is not properly set down.
Always use the guards.
Avoid the chicom wheels. Get a good brand like Walter or Norton.
Dont bend or bind the wheel in the cut. That can cause fractures which can break later.
Lock on grinders are banned at many jobsites for good reason.
   / Using an angle grinder. Dumb questions. #10
Binding in the kerf ( mentioned ) and traveling the wrong direction in relation to rotation are the two major causes of wheel breakage.
2017 Chevrolet Silverado 1500 LT Crew Cab Pickup Truck (A46684)
2017 Chevrolet...
2013 DORSEY 53FT TRIAXLE STEPDECK W/FLOWBACK SEPERATOR (A47001)
2013 DORSEY 53FT...
2021 John Deere 17G Mini Excavator (A45336)
2021 John Deere...
2006 Ford Expedition XLT SUV (A46684)
2006 Ford...
2001 Mack CH613 (A44502)
2001 Mack CH613...
Hesston 4910 Baler (A48561)
Hesston 4910 Baler...
