using chain for a top link ?
   / using chain for a top link ? #11
Hydraulic top link would be the better option. My 3rd service has a float option and the box blade does not work as well in float.
   / using chain for a top link ? #12
I have a pallet fork type attachment with a chain attachment for the top link. Probably not safe for a tall load which could tip back on the operator, but fine for loads only a few feet tall.
I can see how that would work fine with the weight extending the chain and putting tension on it. A problem might arise if, when traveling forward, the heel of the forks caught on the ground, on a curb, or something like that. The fork tips would whip upward and dump the load on the operator. Just don't be carrying a 55 gallon drum of sulfuric acid. :eek:
   / using chain for a top link ? #13
There may be certain things where using a chain for a top link may work, grading is not one of them. ;)
   / using chain for a top link ? #14
Just another reason why one wants to have the float function available for their hydraulic top link.
I haven't had a chance to try it yet, but that's how I'm thinking I'll run my hydraulic top link when pulling my 3pt mounted brush cutter. That will give even more flexibility over uneven ground than is built into the hitch of the cutter. Good point.
   / using chain for a top link ? #15
I once owned a rotary cutter that had a top link made 1/2" thick by 1 1/2" bar stock with a 8" piece of chain welded on the cutter end. I had it many years and that set up worked very well.
   / using chain for a top link ? #16
The chain is attached at two points, with a few inches of slack. You'd need more chain or better yet a solid top link to connect it. I think the intent is to provide limited float to aid in picking things up. I bought this piece at auction. It probably weighs more than a quarter of my TPH capacity. I imagined using it to move firewood on a pallet, but never have. Not very useful, but still part of my attachment collection. :)
   / using chain for a top link ? #17
Steve, I like that. Allows your forks to follow the terrain if trying to get under an object without the points digging into the ground!!!
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
