Using clutch as a brake?
/ Using clutch as a brake? #101
I reckon in the end it doesn't matter because for the most part it has been entertaining
-Don't say that, I'm anxiously awaiting to see the results if slowly releasing the clutch makes a difference vs. dumping the clutch.
Don't give away the answer and spoil it for me. :rolleyes:
Yep, that's what I guessed back in post #31. Showed hand with the "I don't understand what my wife means when she says I ride the brakes" was too far over the top.
I guess it's a good thing that there really aren't people this.....uhm......what's a polite word....?
I've always been taught the only stupid question is one that isn't asked. ;) so if being ignorant of many things concerning tractors is a crime, I stand guilty as charged. lol
Showed hand there and several other places, but if he just happened to be for real he very seriously needed some help. I am sure most if not all were skeptical from at least post #8.
At worst it was entertaining.
I appreciate everyone who contributed to this thread. I read every post, clicked every link and watched every video. :) I learned a lot!
I agree I've been skeptical from the beginning but it's hard to tell..what's second nature to some is foreign to others. He's either very clueless and in need of some one one training or he's being a jack leg wasting people's time when they could be helping someone that's really needing help. I reckon in the end it doesn't matter because for the most part it has been entertaining
this whole thread started from a simple question I had after reading my manual cover to cover. the day I drove my tractor home was my first time ever sitting on one. I've driven automatics my whole life so I've never had to use a clutch. whenever I want to stop my truck, I simply press the brake until it stops. the couple of times I tried that on my tractor never felt right. therefore, I started pressing the clutch to stop moving since it felt more natural. however, I heard of people having to replace clutches so I wanted to make sure I wasn't using it improperly. everything else has been lagniappe. ;)
/ Using clutch as a brake? #106
it seems like that should lessen the initial jerk since it won't start moving as quick. that's a nice looking tractor! was the dealer charging the initial owner 2k for the clutch job or did you negotiate the price down a little?
I believe it would have been a $2k job, but yes the price was negotiated down fairly on condition.
/ Using clutch as a brake? #107
If you are not messing with us then you obviously don't get offended easily. That's a good trait to have.
/ Using clutch as a brake? #108
Okay, okay. I've gone back and forth several times regarding if this thread was real. But like they say: "If you see it on the internet it must be true!" As such I apologize and won't question your sincerity anymore. And it is an interesting thread. :)
wow, 2k is a game changer! I might seriously consider buying another tractor at that price. what did it do before you changed the clutch?
i'm on my way to heaven. what do I have to be angry about? :)
it's all good - no offence taken :)
/ Using clutch as a brake? #112
....and maybe sooner than you think if your going to jump on a tractor and go bush hogging around the edge of a pond with no clue how to stop the tractor or how the clutch works. ;)
Though it may be this certainty that also makes you fearless. :)
/ Using clutch as a brake? #114
:laughing:
/ Using clutch as a brake? #115
The clutch actually was functioning fine. However the splines in the pressure plate that drive the hydraulics stripped out so it had no hydraulics or pto. Once I split it the I found the throw out bearing was bad so I went ahead and fixed it all while I was in there.
Why buy another tractor just fix what you have then you know what you have.
/ Using clutch as a brake? #116
Well if you are being serious then I to apologize if I offended you which from the looks of it nobody has offended you lol. Just kind of hard to tell sometimes if someone's being serious or not. Hope we all answered your questions and we all got a laugh or two out of it..and hopefully we can help you again.
/ Using clutch as a brake? #117
Get some steel toe work boots. I don't drive mine without them. Plenty of hard sole to hit both brakes.
/ Using clutch as a brake? #118
i venture to say this thread has gotten several good chuckles. i know i have. kinda like a good book you wont put down because you want to see what happens next. its the only thread that i have kept up to date on with this many posts.
/ Using clutch as a brake? #119
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2007 MACK CHN613 DAY CAB (A59905)
2007 MACK CHN613...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
