Using FEL controls for rear remote
   / Using FEL controls for rear remote #11
You are right I meant power beyond. I was specifacally talking about hooking up a back hoe also. By taking the Power Beyond you do lose the 3 pt function but with a back hoe attached you are not going to need the 3 pt function anyhow. Also ther is now powering of the whole circut since you are only using the 3 pt. case to dump your return into froom the Back hoe. This goes to the sump and not into the 3 pt circut.
   / Using FEL controls for rear remote #12
Another consideration if you use the FEL control valve is the relief pressure on the FEL valve is less than the hydraulic system relief pressure and depending on what you are doing you may not be satisfied with the performance.
The best solution is to add a rear remote control valve made for your tractor, you won't regret it.
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2008 Ford E-150 Cargo Van (A51692)
2008 Ford E-150...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
